John_Progess
When you re-torque the heads after startup, do you loosen the head bolts then go through the proper sequence to torque them to the required setting or do you just check each head bolt to see if it is still at the proper setting. My concern is the piston liners and loosing the figure 8 seal if I loosen the head bolts. Is there a chance of loosing the seal and water getting into the oil system or am I concerned for nothing. Thanks and have a good day!
John
John
