TR4/4A Top rivets
Rut
Afternoon all...I bought a box of rivets, .25 X .75" with a flat top to replace a couple of rivets that were broken on my top frame and the box contains 65. I'm just guessing that I won't use that many rivets in my lifetime and I'll make them available if someone else needs some. Just pm your needs and once I receive mine I'll send them out.
Rut
Off topic perhaps, but that reminds me. When you drill out a rivet, is it typical that a larger one must then go in? Assuming you did it correctly?
Are you talking about drilling out the hole and making it larger? In my case the rivet is gone and a bolt lives there now and an original size rivet goes back in. If I was removing this style of rivet I would use an angle grinder to remove the end that was accessible.
Rut
Rivets have been delivered and installed! The 3/4" length was cut down 1/8" and it fit perfectly...just inserted it and peened it over with a hammer with an anvil as a back stop. You can use a 5 lb or larger sledge and do the same thing, it didn't even mar the new paint job. let me know if you need any, I'm rivet rich!
Rut
