See if you can catch what happened. Wanted to set point gap, so put the car in 2nd gear and slowly rolled the car forward and backward, until points were on highest point of cam lobe.
Set points to correct gap.
Started engine, but got bad "klunk" sound immediately on first plug firing.
Checked timing chain alignment with cam bearing and crankshaft. All correct.
But timing light shows plugs now firing 30 degrees advance - not the TDC I had before I reset the point gap.
What probably caused the change to such a big advance?
Mickey - you might be interested in this.
Tom
Tom
