The 100-4 fuel tank is dry as a bone. It hasn't had gasoline in it for years. I shake it and tip it in all directions and flakes of rust colored junk come out the filler pipe. Some is rust no doubt, and some is dry residue from the last time it was slushed. With the baffles in the tank and the small filler pipe opening I can't seem to get it all out. It would seem my choices are:1) new tank (pricey) 2) slush it again 3) run it the way it is. I have an inline sediment filter between the tank and the pump. I don't trust it to do 100% of the job. I can't run the risk of flakes of any type getting to the carbs or worse, into the engine. The exterior of the tank is very clean with no evidence of leaks or weak spots. I don't like the idea of gooey glue like stuff in the tank but if anyone has had good luck with it I would like to know. Otherwise what would YOU do?
Hi Guest!
