healeyboz
So here is the deal. When I first dropped in the motor I had a small leak coming from the speedo cable. It lasted for awhile until I could figure just what in the heck was going on. I fixed the leak with a rubber grommet, drained the tranny oil and replaced the oil. I believe that I "overfilled" the oil and now I know that all was not out to begin with because I don't think one can actually drain all of the oil without tilting the tranny up and draining out the output shaft. ??? Dunno. The transmission never leaked other than out the speedo. Once I fixed the speedo issue and filled her up I took her for a drive and when I got home had oil all over the place. It came from the drain hole under the clutch. The motor oil level has never changed. I have to replace the header gasket and motor mounts so the pull is not that big of a deal. The only issue that I really have is that I have to remove the freshly painted bonnet. What do you think?
