philman
i noticed a problem on my '76 tr7 fhc. the outside of the front tires wear excessively. If you look from the front end you can see that the top of both tires are pushed out.
I have replaced the subframe bushings, control arm bushings, ball joints, tie rod ends, sway bar bushings. I am using tr8 strut assemblies with uprated springs from TSI, but i chose to keep the stock sway bar so that it wouldn't ride too stiff and am using the original lower control arms.
Am I going to have to change to a bigger sway bar to get proper tire wear, or is something else going on? I didn't notice this until I did all the front end work, so I don't believe the camber was off before.
