I have seen brand new tires with the same depressions. Don't like it but there doesn't seem to be an actual problem. Doubt if it is caused by damage.
Tires do get brittle & the tread gets hard. Your old tires are likely to fail much more drastically like losing a tread or blowing. At the very least, new & much softer tires will give a better ride, more grip & less likely to fail. I replaced a set of 10 year old tires that had 100% tread due to hardening. The rubber durometer reading (Shore A Scale) on the old tires was 90. The new tires measured 70 & had much better traction.
Hi Guest!
