mightymidget
When I messed with VW Bugs I always set the timing by placing crankshaft pulley at the timing mark. Then I took a test light and hooked to the points so when I twisted the distrubtor the light would come on and timing was set. then I would tighten dist down and put the cap on and it was timed properly.
Anyone time there engines like this. if so where do you set your crank pulley for a 1275? I don't have a timing light.
I want to go through my ignition systems real good before I take weber apart. so I know it will be right once I go through the weber and put it back on.
It has been 30 years since I did this so I hope I am remembering properly
Hi Guest!
