Have a '76 B converted to dual AUD326 carbs (from a 1969, I believe with spring loaded needels, recently rebuilt and shafted). Have had a persistent miss as if carb balance was wrong (checked and set) or not enough fuel. Electronic fuel pump (has plenty of fuel). Am contemplating changing to a 25D distributor since I really can't get the darn electronic sensing unit to stay put on a Crane electronic conversion. Even if I don't, very confused about initial static (and strobe) timing. Bently manual states that the vacuum advance is present but not connected (for 1976 18V801 engine)and gives me various centrifugal advance readings at different rpms. If I put in the 25D4 points distributor which has also been rebuilt it gives me once again a number of readings for different rpms but much different and with the vacuum tube disconnected (and I'm assuming plugged). Can anybody explain what I should do here. I know I sound dumb on this but I have tried everything and just don't know which settings I should be using with the dual carbs and points distributor, or even with the electronic. I just cannot seem to get the kind of response I should be getting, especially at higher rpms.
Thanks
Thanks
