I know we've been over it before, but I hope you will indulge me a few stupid questions about timing. I have a 73 TR6 with a retard vac on the dizzy routed to the valve on the upper hose, then to a port on the bottom of the rear carb.
1)I want to plug both the port on the retard and the carb. Can I do that? If I can do without that small long hose and valve on upper hose, I would like to.
2)What do I plug it with?
3)Then do I still set it at 12BTDC-adjust carbs-12BTDC etc.(tune).
Thanks.
Thanks.
