Wedge Timing my TR8
Hey, Larry -
That boot-mounted battery does present a problem, doesn't it?
I have a battery charger that I set on low-amp output and use that as the power source.
Mickey
On some cars, there is a terminal on the fire wall where the battery cable passes thru it. On others, you can attach to the terminal on the starter or the alternator. You can also use a set of jumper cables from the battery to the timing light. I like to install a small fuse panel similar to a MGB fuse box behind the passenger headlight. It has constant and switched power there. From that panel, I can draw my power for things like electric fans and relays, or use it to attach a timing light. Makes working on and modifying TR8s a little cleaner and easier.
If it has a 4-barrel I get from the choke hot lead, If its stock I get it from the solenoid wire on the back of the manifold.
Thanks
TheWedgeshop.com
