I just installed a new flamethrower electronic distributor and need to set the timing. My timing light isn't adjustable. To confirm the proper way for my 57 100-6 is to set the timing 3/8" to the left (veiwed from front of car) of the TDC notch?I was aided in setting the timing on my BN2 by a Norman Nock article in his Tech Talk book. He lists the following timing measurements for stock diameter crankshafts: 100-4, 6 degrees before TDC, 5/16 inch on the pulley. 100-6, 6 degrees, 3/8 inch. Mk I, 5 degrees, 5/16. Mk II & Mk III, 12 degrees, 3/4 inch (Dave - good guesstimate). I believe the 100M with the advanced curve is 14 degrees but am trying to confirm that and will interpolate from the 5/16. Mike
No! As viewed from the front, your engine rotates clockwise. A mark on the damper/crank pulley that indicates a BTDC(before top dead center) timing setting will be to the right of the existing TDC mark.
Why not just buy an advance timing light; then, measure total advance and let idle fall where it may? If you have positive ground, a plastic case is best lest electrons escape and run wild on your chassis:
https://tinyurl.com/zybbqaq
... how can the advanced timing light be 100% accurate with so many different diameter pulleys out there? I guess it's just a ballpark reading?
