Bret
Hi folks,
I just recently installed the Pertronix Ignitor & Flamethrower 1.5 Ohm Coil (Ballasted) in my 78B and am vary satisfied with the improved overall performance. I also installed up rated performance plug wires and opened the gap on my plugs to 34mm to better accommodate and take full advantage of the hotter coil.
Soon after the upgrade however I have noticed that my timing strobe light started to give out on me. Flickering on & off at erroneous intervals while setting my timing. I did manage to get my timing set before it gave out altogether, but before I start looking for a new one I have a question.
Could the hotter coil producing upwards of 40K volts, damage your common everyday timing light?
If so – I’d welcome any recommendations on a Timing Light that is a little more robust?
