Good morning all.
I'm going to check the timing today. I've had a fast, varying warm idle since I got the car; can't get it lower than 1200rpm and it varies from 1200 to 1800 all on its own. Checked for vacuum leaks, throttle shaft play, etc.
Figured I should start with the basics - timing. Engine has slight ping on hard acceleration under load, but other than the idle issue, seems fine. Seems lots of folks here have "fast idle" problems.
There's a vacuum advance on the DM2P4 dist (standard, no electronics). Should that vacuum line be disconnected and both sides plugged when initially working on timing?
Thanks.
Tom
Thanks.
Tom
Hi Guest!
