You may have read the first part of this in my previous engine construction post. I wanted to start a new post because I need specific advice now before I completely loose my mind. (which is easy enough done at the best of times /bcforum/images/%%GRAEMLIN_URL%%/wall.gif ) As I start, please remember
1. 1500 engine
2. high stress level
3. simple words in answer - thanks
History: I took the block in to be cleaned and they finished taking out the pistons/ cam/ crank/ timing etc at the same time. I'm now ready to put it together but I have no previous measurements.
I have found the timing marks on the Cam shaft sprocket and could not initially find the mark on the crankshaft sprocket. I think now that I have found the mark on the crankshaft sprocket. There is a light scratch (pointing outward) along one of the gear teeth that is unlike any other mark on the gear. At any rate, here is my logic, can someone confirm or correct - thanks.
1. The crankshaft sprocket installs with the thickest flange toward the engine. (the scratch is on the thinner flange side)
2. The timing marks on the sprockets must be the same across any 1500 engine. In other words, they must be interchangeable otherwise VB or Moss could not sell them individually.
3. Therefore someone out there should be able to confirm where the mark is since it should be the same on every car.
4. There is a tooth that lines up with the "key slot" on the sprocket. The scratch is on the second tooth to the right of this. (see attached picture -note I drew a line with a sharpie, the actual scratch is on the gear tooth in the same direction) Is this where yours is?
5. See attached diagram. What I can glean from the manuals is this. When the timing chain is in the correct position, there are two things that should line up. a) the two timing marks in the sprockets (blue line) and b) the two marks (one on camshaft and other on sprocket AND the outer edge of the crankshaft gear flange (red line) Is this correct?
6. In terms of assembly order, would it make sense to install the crankshaft and the camshaft and the timing chain first. Then I can move them easily without pistons to impede the crank's movement?
7. Presumably, when the engine is assembled, there is something else I could measure to ensure the timing marks are properly alligned. That is to say, if piston # 1 is TDC then some valve is open or something to that effect. what sequence would that be?
I think that is all my questions, These may be really dumb questions but I am really anxious about this. Thanks, JP /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
1. 1500 engine
