I have a 1500 MG Midget.
I am ordering replacment crankshaft, camshaft timing gears and chain, do the timing gears typically have the timing punch mark on the gears already there?
If not how do I do the timing?
If the timing pump marks are there how do I check to make sure they are accurate (is there some kind of double check that I can do)? I would rather not compare them to the old ones, just in case the old ones are innacurate.
Since I have part of the engine open (the timing cover off) but still in the car, is there anything else anyone would recommend I replace at this point that would allow easy access?
