paulsherman
This may be a stupid question, but will ask anyway: How do you hold the tie rod end from turning when fastening it to the steering arm. New tie rod ends, with castellated nuts I was able to put the nuts on and turn them until they met the nylon inserts, then the whole **** things begins to turn. Any hint or trick will help.
Thank you
Thank you
Hi Guest!
