The trans tunnel is now covered on inside and outside with insulation. I used the foil covered bubble stuff from Home Depot. Works well. Glued it down with 3M Trim adhesive. Easy stuff to work with. All seams were then taped with aluminum tape. Works real good. I left a bit of an uninsulated edge around the dip stick hole and the shift lever hole so the plug and boot can afix without stuff in the way.
Problem is, the dog dish shift lever boot does not fit. It has three grooves, but none seem the right size for the hole! This seems to be the right boot for the side shifter according the the catalogs and resto books.
Is there a source that sells an accurate and correct one?
Any help and experience is appreciated.
Hi Guest!
