roofman
Following up on my " funny feeling in steering " post.
I removed the steering wheel and hub and got out my Bentley manual.
I can grab the steering shaft where the steering wheel hub attaches and move the shaft in and out over 1/4 inch. The entire shaft moves in and out of the steering box.
In the firewall area where the shaft comes thru, the saftey clamp is 1/2 inch away from the firewall, and some type of white bushing material is exposed and loose from the cut out in the firewall, like it doesn't fit.
The bently shows the clamp directly up against the firewall, not 1/2 inch away.
There is also a little side to side play in the shaft.
This can't be right, is it?
