Randy Forbes
Weber carbs. Comprising not less than one hundred forty three pieces (each, of three carbs; not counting the butterfly shaft which you should not disturb). From three years of non operation while sitting in a body shop, the gasoline evaporated and rendered the poor carbs useless. They couldn't pass gas if you gave them deviled eggs! I completely overhauled one of them this evening and I'll do the other two tomorrow. No problems and I've reaquainted myself with all the internal circuits again (previously memorized and forgotten).
Weber carbs; made to be taken apart. Piece of cake.
While I was out of town this past week, I had a set (minus the safety gauge) of VGC used gauges delivered. Only a minor bit of polishing on the chrome rings and cleaning of the faces and glass. Tachometer and speedometer came apart and went back together without a hitch. I even "zero'd" the odometer in anticipation of getting a fresh start with the "totalizer" when the car finally hits the road.
What I did learn today though, is that the fuel gauge was never meant to be taken apart. heck, there's hardly anything to it! But (I thought)it too should have the face wiped and glass cleaned.
Well, the needle bent so easily, I figured I'd better pull the back off so I could properly straighten it out. LOL! What are these separate coils doing in here? Oh, you mean they're spaced a certain distance to calibrate the **** thing?!
Oh well, I did manage to get it back together, but I just didn't have the enthusiasm to test it to see if it worked. I'll save that for some day when I've run out of things to discover if they should or should not be taken apart...
