Yeah I read that too. That guyโs gonna be in heap big trouble if heโs flying in controlled airspace.I read where there's one flying around the Los Angeles area,
possibly causing problems with air traffic.
OK, you guys are officially old. 3 hypothetical and negative comments.
It's restricted airspace for a reason. If they catch the guy I would think he's likely to face some serious fines and possibly jail time.Not very clever to be zipping around with one in restricted airspace, for certain. And LAX is a BUSY bit of air. Better to be doing it a lot further inland, I would think.
Yeah, I've seen that. The report said it(he) was spotted North of LAX. They don't say he was in restricted space. North of LAX is Santa Monica airport's airspace. In my paragliding days I had to learn about controlled airspace. I've forgotten most of it, but I believe there would be some uncontrolled space close to the ground mid way between.
That's true, they didn't say if he was in restricted airspace, just that he was "near LAX." My son flies into LAX (737) quite often, maybe I'll ask him if he knows.They don't say he was in restricted space. North of LAX is Santa Monica airport's airspace. In my paragliding days I had to learn about controlled airspace. I've forgotten most of it, but I believe there would be some uncontrolled space close to the ground mid way between.
We wouldn't want a Pub thread to stray off topicRegardless, LAX is half a world away from Dubai.
Several years ago this same pilot crossed the English channel. Flight time is about ten minutes. The chute seems to be the standard landing but I hadn't seen him VTO before either.I didn't dig around to try finding the duration for the engines, but the "time-to-climb" looks pretty good. He wasted no time getting across that water at lower altitude so he could get enough air twixt him and the floor to deploy the 'chute though. Seemed to me that each of those video cuts would indicate the time the burn lasts. Either be low enough to make a powered landing or high enough to use the 'chute. A no-power glide angle likely a couple degrees better than a concrete block.
I just found out Google Earth has the ability to show airspace around airports in 3D. I haven't figured out how to make it work though, just seen pictures.That's true, they didn't say if he was in restricted airspace, just that he was "near LAX." My son flies into LAX (737) quite often, maybe I'll ask him if he knows.
We wouldn't want a Pub thread to stray off topic(that almost never happens)
That makes sense.LAX isnโt restricted, itโs Class B controlled airspace.
