Jim_Gruber
I swear these cars must have been built by Midgets. Started work on replacing Choke Cable last night. For those who have never experienced this fun job imagine placing your hand in a vise, tighten, and then using razor blades to skin off any exposed flesh, all while standing upside down on your head. Access to the choke cable is at best difficult if you remove the radio console. If you want to save time and hassle and attempt it with just speedo being removed it is to say at the least challenging. I have avarage sized hands and getting the short enough wrench behind the dash and in place to loosen the nut on the choke cable took about every one of my tools to find one that worked and would fit.
Old cable is out, pull string is installed to pull cable through the firewall, and another hour or two will have this job completed.
Speedo needs to come out
Rt Turn signal needs to be unscrewed so you can get access with wrench
A short adjustable and I mean short stubby adjustable wrench works to get the nut loose on back of short cable.
Use tape to attach a pull string to Choke Cable as you pull back through firewall.
Attach lock washer and nut to choke cable
Use Pull String to pull choke cable back out through firewall.
Find a 10 y.o. child with small hands who is interested in things mechanical.
Loosen one side of speedo nut, use long, long, long needle nose pliers, 12"+. That $4.00 tools you can never find a use for, works well to loosen thumbscrew wheels.
Get second side loose as well but rotate speedo in the dash to get better access to thumbscrew wheels.
My goal of replacing the dash with a fiberglass replacement will need to wait until next year after my hands heal up.
