Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
On the early 3000 they fitted electric choke system which did not work very well so it was replaced with a manual choke
My car has this electric choke and as its a rare system so i want to keep it but have no information on how to run the wiring
Section DDD of the shop manual has a good description of the thermo carb. Wiring appears pretty simple, ignition feed to thermo carb coil, other side of coil to thermo-switch then to ground.
Thanks for the replys if any one has any photos of the system that wouild be a great help as some people say the wiring is part of the main loom others say its a seperate loom
