Hap Waldrop
I seen transverse blocks coverted to inline, mostly you see it with the A+ blocks, you need a crank from a inline motor, pan, rear and front main caps (which means you have to line bore) from inline motor, and you need to make a few additional drillings to the front and rear of the block to accomondate the inline engine plates, bottom line it's more trouble than it's worth.
When you compared FWD to inline, alot of components do interchange.
All heads do interchange, some of the Mini heads are 11 stud, and yes a inline block can be converted to 11 stud, in my opinion, another waste of time. You don't want to use a 948 head on a 1275 or opposite for obvious reason, ( valve size spacing, combustion chamber volume, etc.)
1275 Connecting rods interchange, except for the A+ rods which have a larger housing bore than all the other A series rods. 948 connecting rod have a smaller pin size (.625" vs .812") 948 rod use pinch bolts to secure the pins, 1098 rods which also have .625' pin have a bushing and can be used in 948s
Cams, pushrods, lifter, rocker arm assmeblies, all interchange on all 1275s, however late model Mini used a slot drive cam, this set up can be used in a earlier 1275 inlline engine and it exactly what I used in both Drew and ray's engine. Earlier 1275 engine used a star drive for the oil pump, and 948 and 1098 used a pin drive for the oil pump. You can use a star drive or slot drive cam in a 948/1098 without a special N/A available oil pump or a oil pump pacer (so I've heard, never had a reason to do this)
Timing gears interchange, however the early car had a single row chain and the later cars had a duplex chain.
All rod bearing are the same for all the A series engines excpet the A+, 948/1098 had msaller main journal, until the later 1098 10CC motor which is when the 2" main were developed and carried over to the 1275
There's more, but that a start
