I realize that this is water over the dam--WAY over the dam--but I suspect that I can get a definitive answer here, anyway. So what if it's 40 years too late to be useful?
Back in my wild and profligate youth, I had a Triumph TR4A, 65 or 66, can't remember which. I got it new. Drove it 50,000 miles and put five (count 'em!) clutches into it. The main (but not the only) problem was the front oil seal in the transmission. I'd put in a clutch, drive a few thousand miles, and it would start slipping and chattering. Take it apart, find transmission oil flung all over the inside of the bell housing and contaminating the clutch disk. Replace the clutch (the whole thing: disk, plate, release bearing), and of course the transmission oil seal, and repeat the cycle.
So, my question: is this characteristic of the beast, or was I just unlucky? If the latter, how would you fix things so the front transmission seal doesn't start leaking in a few thousand miles? Maybe grind, machine, or polish the shaft where the seal contacts it?
The answer may have some practical bearing, as I may succumb to the urge to get another TR4 someday. Thanks in advance for your comments.
