So here's my (rough) project list for the Tunebug. I've got a week off in April, so I'm going to try and work through as much of it as possible. I'd love any comments on any of these projects, so that I can be as prepared as possible.
<span style="font-weight: bold">Rebuild rear hubs</span>
This is almost done, just need to tap in the bearings and install them on the car -- not that I know exactly how to do this...
<span style="font-weight: bold">Install newly rebuilt front suspension/disc brakes</span>
I've got rebuilt A-arms, calipers, new brake disks and pads, and need to yank the old stuff and install the new stuff. Attached to this project is new tie rod ends, which I have in hand.
<span style="font-weight: bold">Run new brake lines</span>
I've got the hard lines and soft lines in hand, and a bending tool. The master cylinder was rebored for the disc brakes, so that needs to go in as well.
<span style="font-weight: bold">Run new fuel lines and an electric fuel pump</span>
Switch to a 1275 needs an electric fuel pump, so we'll do that as well as run new lines. I've not done this before, so not sure what I'll need to engineer. I also need to decide between the original (slightly grubby) fuel tank and the new replacement tank I have on hand.
<span style="font-weight: bold">Fix parking brake</span>
This is due to the swap to the later style rear brakes. The rods will need to be lengthened, and I'll probably need to have that done by someone else as I don't have metal fab tools. Not a huge priority, just something that needs to be done.
<span style="font-weight: bold">Refurbish transmission</span>
I've got 2 rib case transmissions to choose from. Both were listed as in good working order, but I've not checked either one. No parts on hand for these.
<span style="font-weight: bold">Install rebuilt engine</span>
I've got my ACME Speedshop motor all ready to go into the car, just need the car and transmission ready for the engine.
<span style="font-weight: bold">Final bits</span>
This includes radiator, carbs (already rebuilt by Hap), exhaust (headers need to be coated), etc. The final stuff to wrap it all up.
Realistically, I'm hoping to have the car back on its wheels by the end of the week of work. This would mean getting the rear hubs done, the front suspension/brakes swapped in, and the brake lines and master cylinder in. If there was still time I would work on the fuel lines. It would be really nice to have the car back on its wheels, and getting even this set of projects done would free up a bunch of garage space.
