Ok, in a previous post I told you that I have the motor out of my Spitfire in hopes of figuring out a persistant oil leak that has been happening for a long time. Despite changing the rear seal twice it continued to leak. Now that I have the block on a stand and the gearbox on the floor, I'm even more puzzled that ever. If the oil leak were coiming from the rear seal, as I've long suspected, then it seems the back (engine) side of the flywheel would show oil, would it not? However, the back of the flywheel shows no hint of oil - just a bit dusty, but no oil. So does this eliminate the rear sear area? It doesn't seem to leak much when the motor is running, but pours out several tablespoons full when you shut it off. Another possibility is that the oil dis coming from the gearbox. Someone mentioned the possibility that the input shaft seal could be bad. Only problem is, according to the pictures in the Haynes manual, this particular gearbox on teh later Spitfires does not have a seal...just a bearing with an "oil thrower" on the shaft behind the bearing (the side of the bearing facing the inside of the gearbox). When I look under the car it sure seems as if the oil is leaking from the engine. I suppose it still could be from the seal...maybe too much crank case pressure? But I'd think if that were the case I'd see oil all over the engine side of the flywheel - but I don't know that for a fact.
As long as I have the motor out I am going to have the crank inspected and sleeved if neccessary and I will probably chenge out the bearings in the tranny too, but does anyone familiar with these later Spitfires have any other thoughts our suggestions?
