newmexTR3
Hey guys,
I hadn't given you a full update yet on the 3, but here it is: The car was finally delivered from Albuquerque to Brooklyn 2 weeks ago. I ended up using Four Corners Transport Services (www.fourcornerstransportservices.com) and even though it took longer than expected for the car to get picked up, they kept me updated and were very courteous. I would definitely recommend them. The car was on an uncovered transporter and the whole move cost about $1150.
Within a couple of days of arriving, I showed the car in the annual 5th Avenue Street fair here in Brooklyn. I was parked alongside a nice group of American classics from the Brooklyn Antique Automobile Association. I joined the group on the spot and met a wonderful guy by the name of Lenny who is the president of the club and has over 70 cars stored in various parts of the borough. As an added bonus, car owners who showed off their beasts in the fair got 10 bucks- which paid for some ribs and beer! I now have some solid leads on affordable garages in the area as well as a nice network of car freaks to tap. So far life with a classic car in the big city has been great. The looks I get when driving through Brooklyn are really priceless.
Now to present my issues to the collective wisdom here:
Just over a month ago I was in New Mexico and had no real issues with the car- it started up fine even when cold (although it would take a few minutes of warming up before it would run smoothly)Since it's been here, I've had major problems with it starting hard, then idling roughly with major backfiring going on through the carburettors. The car rarely ever backfired through the carbs while in NM. Once the car warms up a bit, the problem goes away.
I have a relatively new distributor (less than 5k miles) and the ignition system seems to be operating properly (although I do not have the vacuum advance hooked up, but never have). I have cleaned the plugs and will be replacing the wires this weekend, so i suspect very much that this is a carb problem, specifically the front one.
The obvious environmental factor that has changed is the altitude- In NM I was at bone dry 5500+ feet. Here I'm at sea level with some humidity. I've gone by the book and adjusted the fuel/air mixture with the air cleaners off, but the mix didn't seem to be that much off. However, my plugs are still showing an overly rich mixture.
Other issues possibly effecting this are that the front carb's piston is stinking towards the bottom of its travel at times. I've cleaned it up as much as possible and it functions better, but I think it still sticks intermittently for a second before going all the way down.
Could this be a timing issue? My dad suggested I play with the distributor a bit and see if that makes it any better. What do you think? Any ideas from you guys would be appreciated.
Cheers,
Gavin
Cheers,
Gavin
