regularman
This is enough to drive me insane. New fuel pump and pressure regulator installed. Drove the car yesterday in the heat up a mountain and plenty of fuel and power and the engine ran cool. Then after about an hour of driving the same old crap started again. I took the car on the interstate and got up to 70 and all at once the engine ran out of gas. I backed off on the pedal and it eventually caught up but I could only go about 45. Any faster and it would hunch and carry on. Also at this time the engine started to overheat again. I think the two are related. Engine starving for fuel and this lean condition causes an overheat. I took the car back home and jacked it up and put the rear on stands. The fuel pump was hot as fire. I turned it one and I could see bubbles in the fuel filter between the tank and the pump. I replaced all the hoses and this still is happening. As I recall with the fuel pumps they should shut off when they reach pressure. This one is running all the time. I got to figure this out.
