I'm trying to get at the last of my electrical stuff before I start putting things like <span style="text-decoration: line-through">hoods</span> bonnets on. Anyway, previously, when I hooked up the brake pressure failure switch, somehow current was leaking through such that the starter would not shut off but would keep turning the engine - even with the key removed. I thought it was the diodes - disconnected the ones I could see tonight and no change. So, electrical heads, I need your help.
The easiest way is to look at one of the manuals so,
If you have the 1500 Bentley manual, I am looking at the diagram on page 330. The brake switch is #27. The diodes in question are numbers 8, 9, and 10 respectively. These seem to me to be the only way the power could be leaking. I found and disconnected the diode at #8 and #10. I cannot locate the diode #9 under the dash.
If you have the Haynes Manual, it is page 207. (which is 1978 Midgets I know - but it seems right) Here the brake switch is #29 and the diodes 9 and 10 respectively with a "phantom" diode "penciled in" above #9. Again, it is this one that I cannot find. (BTW - to help you find it, it is in the upper right corner in both diagrams)
I don't know if this matters, but, the brake pressure failure switch and the reverse light run off the same part of the wire harness. Neither were getting power, so, rather than rip the whole section of harness apart to find the short, I tapped into the green feed line at the Stop Lamp Switch (#3 in both). Also, the handbrake warning light is not hooked up.
I know I really don't need to hook this up at all but I want it to be right.
Any suggestions gratefully received.
