Re: The Best Oil - for carburetter piston damper?
just to throw a wrench in the works,an engine is an engine. tolerances, clearances, operating temperatures, conditions(racing,stop & go traffic,cold climate, hot climate, hyway cruising, metal/oil compatibility, is what determines the oil requirements.
Synthetics are superior, period. You cannot break in an engine on synthetics (lubrication is too good),you need the rings etc to wear in to make good seals. Parts need to lap against each other for final fit. That's why you make more power and better economy after the break in period.
IMHO catrol is not good (i have alway found sediment in the container). Mobil 1 100% synthetic is excellent.
I have a japanese (from japan directly) landcruiser turbo diesel that cannot use most north american diesel oil because of the magnesium in it. Japanese diesels run hotter oil temps and need high calcium oil. If they don't the rod bearings overheat and flake apart.(has to do with the magnesium)
So, it is important to consider the additives in the oil as well. most british cars run hot so the heavier weight oil has historically been better, but......,with synthetics, the oil does not break down under high temps like the old oil did so you can run a lighter weight oil and gain power and economy because it flows easier and takes less power to pump it through the engine and returns to the pan quicker. Most manufacturers now recommend 5-30 or 0-30 because of this and the "cold flow" when you start up is superior and start up is considered the highest wear period an engine goes through.
If a higher quality oil saves my engine, that is always the way i will go.
Now filters are another story.There are a lot of bad ones out there.I cut mine apart after an oil change to check filtered contents and to check the quality of the filter.some that used to be good aren't any more.I'd suggest all look into this (search the web, cut yours apart)and compare. one of the biggest names are among the worst.
rob
