A month or so I put up a post about a metallic "clanking" sound I get from the tail end of Greenie sometimes when starting from a dead stop. It usually occurs if I'm not as gentle easing off the clutch. It happens once the car is rolling a bit, and then "clank" -- for those of you who lift weights, it is similar to the sound one weight makes when you add it to a bar that already has a weight on it, but not as loud. I've been all over the tail end, and aside from my loose shock (which made a very different sound), I haven't found anything loose. Last night, I down-shifted from fourth to third going up a hill, and heard the sound as well -- first time I've heard it in that situation.
It's clearly not the clutch and I very much doubt that it's the transmission, since it made it both before and after Greenie's transmission replacement, and my ears tell me it's coming from the back end somewhere. I also had the garage that did the tranny work look around, and they couldn't find any u-joint problems, but it is starting to worry me. I would very much appreciate the collective wisdom.
B.
B.
