T-Series TF Dash Instrument Panel Studs Size
MGTF1250Dave
Aloha All,
Does anyone know what size the studs on the instrument panel that are used to mount the gauges? It seems that it might be a 4BA. I have one broken and would like a replacement the same as the others. Thanks for your help.
I understand their 2BA. PJ
Thanks Paul. I think you are correct for the larger studs and nuts that mount the instrument cluster panel to the steel dashboard. The ones that mount the ignition switch, tach, speedometer, etc. are smaller. I found a correct nut and screw from a spare SU carburetor shaft connector.
