MGTF1250Dave
Aloha All,
I finally began working on this project. My son and I started disassembling my TF last week to start on what is intended to be, an engine rebuild, a change of the ring and pinion gears and rebuild the body tub. So far we have the wings, running boards, engine side panels, bumpers, front and rear valance panels and gas tank removed. I've owned this car since 1972 and the only major work was an engine rebuild in '78 due to a thrown con rod.
The engine most likely has a burnt exhaust valve on #4 (low compression), but I'm sure it is also time for new rings and a through check of all the bearings, rocker arms and valve springs.
I'm going to change out the rear end ring & pinion gear to a lower gear ratio for a slightly higher road speed.
The body tube will be the big project and my son (a carpenter) is excited about the challenge. The main rails and lower portions of the latch and hinge pillars are virtually no existent. I think I will take on this part now to take advantage of his enthusiasm and since we have most of the parts needed.
I hope to take several photos of the tub rebuild to document how we did it.
