wkilleffer
Awhile back, I asked the forum about a problem I was having with the fuel gauge on my 1974 MGB. Time and financial crunches kept me from being able to do anything, and the topic has since dropped off the forum. Now, I can do something, but am not sure what to do.
My fuel gauge has not been working for awhile. After starting the car, the needle will rise up to a point between the two lowest markings on the gauge and stay there. Initially, I thought the float on the sending unit might have failed, but on a really hot day, the gauge came to life and gave a reading that seemed more or less accurate based on the mileage since the last fill-up. But it didn't last too long.
It did it again last weekend. It was a hot day that day. Once again, the reading seemed to be as accurate as those gauges ever are. Something I've noticed both times is that it seems a little balky when it does this. The needle's movement isn't smooth, whereas the temp gauge needle always moves smoothly. It's like a connection's bad or the gauge is having problems.
The temp gauge works just fine. Both gauges are plugged into a voltage stabilizer that might be original to the car.
I've seen a method that's used to test the operation of the gauge that involves some kind of connection to the wire that plugs into the sending unit.
Any suggestions would be appreciated.
Thank you,
-Bill
Thank you,
-Bill
