A friend of mine recently purchased an MGB. The temp gauge does not register any temp change. How can I test the gauge to ascertain if the problem is in the gauge itself, or the sending unit in the head? Is there a way to test the sending unit?
The two radiator fans are also not working. What is the procedure for testing the sensor located in the radiator header tank? Can the fans be wired directly to a switch? If so how can this be accomplished?
Thanks for your input.
Ray
Ray
Hi Guest!
