Hi Guest!
My apologies. I should not have said "miss" as that would indicate a plug issue. The issue is more of an "uneven ,irregular or lumpy idle". You can hear it on muscle cars that have a modified cam shaft only on my TR3 it's not as pronounced as that but similar. I am using a mild street cam but I don't think that would cause the affect? I am also using a TR4A long manifold and an exhaust header if that matters? It very well could be a carb adjustment issue? As soon as the Covid issue gets better I'm going to visit a friend that has a newly rebuilt TR4 that ticks over nicely and see what he thinks.The owner's manual actually tells you to set the timing statically and adjust the advance at the knurled nut of the distributor. Back in the 1960s, that was the only method I used, and it worked fine. I think it is equivalent to about 5 degrees. But the timing would have to be pretty far off to cause a miss at idle, and with the difference in fuels, the original value doesn't mean much anyway. It's hard for me to imagine an electrical problem that would cause a miss at idle but not at speed. Are you sure it isn't carbs or something like that?
I will do a compression check but the car runs fine other than the irregular idle. How is valve adjusting done using a dial gauge?Might be valve problem...Have you done a compression test to help with the diagnosis ?
