Thanks for the replies, I have been reading what I can on the OD and still not sure if I am going to do the minimum or do a complete rebuild. I read a how to on putting the 3/16 pin in and adjusting the arm. It seemed straight forward. I am most likely going to purchase a new solenoid and relay to make sure they work ok. When I undid the solenoid, only the top half came off. I do not know if that is correct? It might be because it came apart pretty clean? Anyways I do want to drain the OD. Would I pull the large brass plug of the bottom? And if so, are there some suggestions for a tool to loosen it?
