I have question about wiring in a temporary ignition switch. I have an old generic switch that has the four lugs on back: acc, bat, ignition, and start. I have one wire from battery side of the switch to the battery. I have one wire to the ignition side of the coil and switch. And one wire from the start side of the switch to the solenoid. My problem is I cannot get the start side of the switch to engage. Do I need a second wire? The switch turns on and off fine and I can push the button on the solenoid to start the car so the ignition side works, but when I turn the key to start nothing happens. My first guess was that the solenoid was defective, but I tried another one and I have the same problem. Why when I turn the key to start the solenoid won’t activate? I just cannot see it. I thought the switch was bad, but if I turn the key to start and check for continuity from the battery side of switch and start side of the switch there is a connection.
Steve
Steve
Also, the body of the solenoid must be grounded for the coil to work, but not to use the pushbutton on the back. You might try temporarily grounding the coil just to see what happens, in case the screws aren't doing the job for some reason (like paint between the clips and body).
