I recently run my TR6 for a while, and when the temperature
gage was slighly above the middle point, I unplug the wire from the temperature sending unit and pointed the electronic
(laser beam) to the sender tip I got a reading of 168.9 degrees.(Farenheith). I understand that the middle point in the gage indicate approx 180 degrees. Is this a good and reliable test? which one is correct?
Hope to any of you that can shed some light to this.
Remy
Remy
