Temp gauge stopped working....any common cause?
Pull the sending unit out of the head (or radiator on earlier models) and put it into a pan of boiling water. Should read 212*F.
Healey Z:
If its the original guage, its the mechanical gas type utilizing a bordon tube behind the face plate. Most common failure is a leak in the tube or bulb, allowing the gas to escape. You can remove it and send out to a repair shop, or buy a new one which is close to original.
If its an aftermarket, electrical type then its a different animal. Start by checking for power at the guage, then the resistance of the sending unit to ground at temperature. That will tell if its the guage or the sending unit.
Let us know how you fare?
Jerry Rude
BJ8
Lotus Europa TCS 'Guenhwyvar'
Randy, Lotus, thanks for the replies.
It is the original gauge and I fear it has loss it's gas. All power and grounds are solid and the oil pressure side of the guage continues to work fine.
Is there a US company that repairs the units?
You have lots of options for repair. Nisonger in the East, Moma in Albuquerque, Palo Alto Speedometer in Palo Alto, West Valley Instruments in So Cal all have been recommended on this and other forums. I sent mine to Foreign Speed in San Diego because I have dealt with them in the past.
Marv J
FWIW, I believe they are charged with ether, which is a liquid (just barely) at room temperature (same stuff used in the old-fashioned toy bird that rocks back and forth into a glass of water).
My otherwise mechanically savvy father refilled one and tried to re-solder the bulb. Fired the bulb across the garage like a 50-cal bullet. Fortunately, we wasn't hit.
I think that's correct. I've seen one burst a leak right in front of me (hissing away). Once it's out, you're out of luck. The small tube that communicates with the bulb in contact with the coolant is somewhat fragile and if it's been wiggled a fair bit, can break or leak where it comes into the gauge. I'd seek a new one (as I've not seen how to repair it with ease).
This is a common repair, cheaper than a new one, and you keep the correct gauge. Mine (for a XK120 but essentially the same) will be about $130 but only because it needs a new capillary tube and the spring-like wire armor. To recharge and fix a leak would have been less than $100. They also clean and check out the oil pressure gauge.
If you want to try a DIY repair, go here:
https://www.ply33.com/Repair/tempgauge
Marv J
Great info!
Not sure about the safety gauge, but the tach and speedo indicator needles on my BJ8 are a press fit. If that's true for the safety gauge you can 'calibrate' without bending anything (at least intentionally).
