twas_brillig
[FONT="]Fuel System:[/FONT][FONT="][/FONT] | |
[FONT="]- add an in-line fuel filter[/FONT][FONT="][/FONT] | |
[FONT="]- a 1275 engine will require an electric fuel pump; there are some advantages to replacing the mechanical with electric (fuel pressure available before cranking; vs PITA factors regards adding if you don't really want one)[/FONT][FONT="][/FONT] | |
[FONT="]Transmission:[/FONT][FONT="][/FONT] | |
[FONT="]- Datsun 5 speed with Rivergate or Gerard's ; life will be easier if you make a cut-out in the top of the bellhousing when installing 1275 engines[/FONT][FONT="][/FONT] | |
[FONT="]- Ford 5 speed (note that this apparently requires body mods)[/FONT][FONT="][/FONT] | |
[FONT="]- fibreglas replacement cupola for Datsun trans swap[/FONT][FONT="][/FONT] | |
[FONT="]Clutch:[/FONT][FONT="][/FONT] | |
[FONT="]- use Gerard's approach to using Datsun clutch with Datsun 5 speed[/FONT][FONT="][/FONT] | |
[FONT="]Cooling:[/FONT][FONT="][/FONT] | |
[FONT="]- later plastic fan[/FONT][FONT="][/FONT] | |
[FONT="]- add water wetter[/FONT][FONT="][/FONT] | |
[FONT="]- overflow tank[/FONT][FONT="][/FONT] | |
[FONT="]Hydraulics:[/FONT][FONT="][/FONT] | |
[FONT="]- get master cylinder resleeved to match disc brakes or clutch changes[/FONT][FONT="][/FONT] | |
[FONT="]Lubricants:[/FONT][FONT="][/FONT] | |
[FONT="]- whatever oil works best for you (Valvoline 20-50 racing oil one of the better ones)[/FONT][FONT="][/FONT] | |
[FONT="]- Redline fluids for transmission and differential[/FONT][FONT="][/FONT] | |
[FONT="]- (please note that the above are my personal prejudices)[/FONT][FONT="][/FONT] | |
[FONT="]Electrical:[/FONT][FONT="][/FONT] | |
[FONT="]- splice in a 'cigarette lighter, mounting it to the wood behind the grab handle/behind the dash; or add some sort of USB power source for your GPS and phone[/FONT][FONT="][/FONT] | |
[FONT="]- switch to negative ground (one our BE's is neg; one is pos; this may impact electric fuel pump, LED tail/brake lights; possibly ignition)[/FONT][FONT="][/FONT] | |
[FONT="]- replace generator with alternator (if you want to have your tachometer maintain original stock appearance, you'll have to build one)[/FONT][FONT="][/FONT] | |
[FONT="]- there are a variety of choices should you need to replace the wiring harness, varying from a low cost duplicate up to a wiring kit with more relays and fuses than the space shuttle. We used an extremely expensive kit that - for my needs and purposes - was more work and overkill than really needed. But it is one heck of a harness[/FONT][FONT="][/FONT] | |
[FONT="]- add a big label on the firewall identifying if the car is positive or negative ground; also add coloured washers/connection covers[/FONT][FONT="][/FONT] | |
[FONT="]- buy an intelligent charger for the battery[/FONT][FONT="][/FONT] |
