taller diff ratios available?
artmck
Are there any taller rear axle ratios available for the B? This might be a cheaper and easier way to get the revs down without buying an overdrive trans. I've noticed that I can almost start in second as it is, so a taller ratio would not hurt, except for drag racing I guess.
What year is your B? There are several ratios for the banjo rear end, but I don't recall if there are any for the later style.
It's a '74, but I have a friend with a very early parts car if things are reasonably compatible.
The MGC came with a 3.07:1 ratio. These are interchangeable and somewhat hard to find. I saw one on Ebay a while ago and it was very expensive-- over $800 I think. A lot of people look for these when they change engines. I thought about it as a possibility befor I bought my O/D.
MGC rear ends are not affordable. For that kind of money you can spend just a few hundred more for a LSD rear end with whatever gearing you want. The advantages with this setup besides limited slip is near silent operation, lower maintenance and longer life.
I found an English site that listed a custom r&p, but it was way more ÂŁÂŁ than an overdrive trans...
I looked at the ratios on the 280z trans, and 5th is only .864:1, which yields 2888 rpm at 60mph, which is still higher than would be nice. A .80 5th gear would be ideal. Not to say that if a 280z trans can be had cheaply that I would not do it. I will talk it around a bit. There is a guy on ebay selling just the adapter plates for this conversion. You still need to make/buy everything else. Probably the cheapest easiest thing to do is find an OD trans.
Torque is what causes acceleration. There are three ways to increase torque, a larger engine, higher compression ratio, or more mechanical leverage in the drive train (final drive ratio).
The 280Z & the MGC have considerably larger engines & more torque.
Since the relatively small MGB engine has little torque to start with, the only option is to increase it with gear ratios.
Low numerical axle ratios, overdrives, or 5 speeds will give lower cruising rpm but must be down shifted to get much acceleration. A four speed with numerically low axle ratio will have to be down shifted to third for acceleration & the optimum ratio may be missing (gap too wide between fourth & third). With small engines, the more transmission speeds, the better.
If originality is not of concern, I believe the five speed with a reasonably high numerical axle ratio is the better way to go. Available overdrives are great but costly & not totally reliable.
I didn't look at the other ratios on the 280, but for sure the B has all of the ratios shorter than they need to be, that's why I originally though that an axle change could accomplish the goal. The 280 has 15" tires, which implies that the 1,2,3 gears are a bit taller, which would be fine.
Horsepower is what is needed for steady state cruising, and I would think that at 2500-2800 rpm, there is plenty of power for cruising, as long as we are not climbing mountains at 60mph!
