G
Hi all,
I tried to convert my RVI2401/00B Smiths tachometer to negative ground.
Since the inside of my tachometer was completely different from the schemes I've found online so far I wanted to reassemble it until I have a proper solution (will probably buy a new one).
However when disassembling the tachometer lying on it's front I heard two times something fall when unscrewing the back screws. The things that had fallen were small plastic black circles. When trying to reassamble it I could not find a logical spot for them however :S It also seems the inside gets too far to the back (far distance from the glass) even with the two black things put around the screw inside at the back.
Any suggestion where they belong?
Images:
https://www.dreas.nl/tach1.jpg
https://www.dreas.nl/tach2.jpg
https://www.dreas.nl/tach3.jpg
https://www.dreas.nl/tach4.jpg (the black things I need to put somewhere)
Images:
