Woodie
Ok back from vacation. And just before I left I change the volatge regulator. I thought the one in the car was not working correctly. The guy at autozone " checked it in car' and said the generator was putting out 17 volts. I then bought a meter and when idleing the volts across the battery are a touch over 12.5 and when the idle is increased slightly it moves upt to 13.5 or so. That is the only thing that changed since I went away for a week. Now when I drive and get the revs up around 3000 - 3500 or so the tach starts to swing wildly, then settles at 0 for a few seconds, then comes back to life. Of course this happens when moving through third gear , and occasionally in 4th when I am at about 65-70 MPH. The car is running great, it is a 1970. I checked all the white wire connections under the right side of the dash and the distributor wire is firm. Any thoughts???
