Tach problem
TypeRboy
I wasn't sure if I asked this before, but my tach reads high ( idles at 3500 rpm.. etc ) The tach is new, positive earth, and standard point ignition. The coil is a lucas sport coil and I am not running a balast resistor. ( the tach box showed nothing about needing one..) Does anybody know what might cause this, or if the tach's are adjustable. ( this is an nos early tach bought from Lotus )
I might as well not have a tach for the good it does me.
[ QUOTE ]
...The coil is a lucas sport coil and I am not running a balast resistor. (the tach box showed nothing about needing one..)
[/ QUOTE ]
Probably doesn't but this is easily checked by testing the resistance across the 2 terminals. If about 3 or 4 ohms then no resistor required. If about 1.5 ohms then it needs an external ballast resistor.
This is on the Elan. I have a few wiring diagrams, and the harness is brand new. Everything looks right for wiring, I can't imagine how I could hook up a tach to read three or four times the actual rpm if I tried... Yet somehow it does.
