Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
New Healey owner - 100-6 with 3000 engine. Have oil leak at tachometer cable connection located just below distributor. Is there a gasket for this connection? Could not find any drawing detail for this part.
If you remove the drive from the takeoff you'll likely find ther remnants of the seal. If you can't find or make a replacement post a picture of what you find and someone on the list will tell you how they solved the same problem. There's nothing new under the Healey sun.
Will do that-should have done it before, was just trying to find info on all of the gaskets I need prior to disassembling anything. Thanks for the reply.
