Sway bar bushings?
here's a SECOND to that one!
Don't use poly bushings anywhere unless you like creaking noises. After using poly bushing for 6 months, I switched to the bushings from Moss.
Poly bushings are the only way to go. You do however need to use the correct lubricate on them before installation. I successfully installed them 10 years ago. Never a squeak.
So poly bushings don't flex like the rubber ones?
I have poly bushings for the links because they compress less, but not the bar-to-frame bushings.
