I’m looking at not attaching my ADDCO sway bar to the bumper irons... rather, Welding a short 2x2” mild steel tube to the end of each frame and connecting to that. I would also forgo that short extension to the lower wishbone arm and attach the sway bar directly to the middle spring pan bolt.
The only issue I have is whether it’ll have sufficient freedom of travel as the suspension moves through its whole range. Unless one of you thinks of another. Especially interested in Tush’s opinion, since he has one mounted to his bumper irons. (You think nobody watches your videos?!)
Hi Guest!
