Jeff,
As far as the trans, the smooth case was working well, so I'll use it gently for the time being. I'll keep my eye out for a rib case trans for the future. Thanks for the tips on exhaust and thermostat housing, that saved me some scrambling later. The elec fuel pump was already on my list of needs.
The 948 had lots of problems, it appeared strong when I first got the Sprite, after a couple of years started overheating, leaking oil out of all openings and making suspicious sounds. After I pulled the engine, I found the pistons, rings, bearings and crankshaft were in bad shape. My brother gave me the 1275, so I decided to have it rebuilt. I plan on using the 948 generator w/tach on the 1275 - do you think that poses a problem? I'll hang on to the original 948, it could be rebuilt in the future.
Thanks for the info.
Charlie
